Tools for use with a press - Can-Am ATV Forum
 1Likes
  • 1 Post By iam_canadian22
post #1 of 6 Old 05-12-2019, 01:18 PM Thread Starter
Question Tools for use with a press
Morning Everyone,
I was wondering if someone knew of some where or some one who builds tools for pushing in and out the bearings from the knuckles as well as for balljoints.
Doonz is offline
post #2 of 6 Old 05-12-2019, 05:30 PM
iam_canadian22's Avatar
I just use a big socket to press out old one then use old bearing to press in new one
Sent from my SM-G960W using Tapatalk
JohnnyHildo likes this.
16 maverick xmr: sport low bypass, amsteel blue synthetic rope,
to come: ALOT
'15 xmr 800: 29.5" s/w OG oulaws, Sirius led light bar, can am/yoshimura slip on, dobeck gen4 afr+, QSC primary SOLD
iam_canadian22 is offline
post #3 of 6 Old 05-12-2019, 06:19 PM
Born2atv's Avatar
I picked up a ball joint kit from Princess auto when they put them on sale. Makes changing ball joints easy. As for wheel bearings I watch some You-Tube videos and once you have either front or rear hubs out its pretty much like iam-canadian 22 said.
Born2atv is offline
post #4 of 6 Old 05-12-2019, 10:15 PM Thread Starter
I picked up the 10T Hydraulic bench press from PA.
Worked awesome to pop the bearing out. I was hoping maybe someone had made a tool to hold the knuckle to reinstall the bearing.
I bought this https://www.princessauto.com/en/deta...it/A-p8354714e for balljoints but I don't think it will work to reinsert them. Was hoping maybe someone had made a kit for the press to do it
Doonz is offline
post #5 of 6 Old 05-13-2019, 03:54 PM
Born2atv's Avatar
[QUOTE=Doonz;1186922]I picked up the 10T Hydraulic bench press from PA.
I bought this https://www.princessauto.com/en/deta...it/A-p8354714e for balljoints but I don't think it will work to reinsert them. Was hoping maybe someone had made a kit for the press to do it[/ I was able to reinstall my ball joints with this same Ball Joint kit. I borrowed a friends snap on 1 7/16 socket, it needs to be 2 1/2" high. If I remember it fit tight around ball joint and allowed ball joint to bush into a-arm socket. Maybe try different sleeves for wheel bearing, but like I seen on you-tube most just tap them back into place.
Born2atv is offline
post #6 of 6 Old 05-13-2019, 10:17 PM
I used that tool last week to change a lower ball joint. Used included tubes to push out the old ball joint, a bit of penetrating oil first, then after a few minutes, while under tension a couple taps with the ball peen hammer and it came right out. To install the new ball joint, I used a large socket that fit over the rubber cover but still caught the shoulder of the ball joint. I place the ball joint in the freezer for an hour or so to shrink it a bit. Went in very easy.
2013 Outlander 650 Max XT
BRP fairing, mirrors skid plates and rear box
SYMTEC hand/thumb warmers
Trapper front box
GARMIN Montana 600
styk is offline
fuel pump fuse and related questions and help from a great guy streetglider Can-Am Outlander 9 03-01-2019 08:44 AM
Fuel pump fuse CanAmVOL Can-Am Outlander 18 10-05-2018 09:23 PM
Fuse Block Add-On? nc-mudpuppy Can-Am Defender 1 04-09-2018 10:51 AM
Clutch tools available streetglider Can-Am Outlander 1 02-09-2017 07:34 AM
melted fuse block 08 500 renegade sol Can-Am Renegade 2 12-07-2015 02:52 PM
