Can a belt change ur top speed? - Can-Am ATV Forum
 1Likes
  • 1 Post By iam_canadian22
post #1 of 3 Old 05-13-2019, 08:00 PM Thread Starter
Ok I know it might be a dumb question but right before I got my ecu reflashed I changed my stock belt(which I burn a little last time I got stuck in the mud) and I put on the cheap gates g series belt (the $52 one, Amazon) anyway I had did the belt break in cycle right before I sent the ecu off, and now my quad doesn't have the same top end before I would hit 73 mph, now I'm only getting 68 mph, I know it's most likely from the flash but I'm just trying to make sure
Blade Boomer is offline
post #2 of 3 Old 05-13-2019, 10:26 PM
iam_canadian22's Avatar
Yes a belt affects top speed. Belts vary in length and width by a small margin and since you cant adjust belt deflection on stock clutching your top speed will vary
Sent from my SM-G960W using Tapatalk
25TH INFANTRY likes this.
16 maverick xmr: sport low bypass, amsteel blue synthetic rope,
to come: ALOT
'15 xmr 800: 29.5" s/w OG oulaws, Sirius led light bar, can am/yoshimura slip on, dobeck gen4 afr+, QSC primary SOLD
iam_canadian22 is offline
post #3 of 3 Old 05-14-2019, 01:56 PM
25TH INFANTRY's Avatar
not a dumb question at all. yes belts can affect top end and RPM for the reasons Cad22 mentioned. i noticed it with my gates Carbon and Brp mav belts. With both belts i had to change the weights in my primary to get the Rpms back up. if you got a gates for $52 i believe you got the kevlar. if you have an after market primary just lighten up the weights a tad. Or you could wait a few hundred miles and see if the belt breaks in a little more. i believe this is caused by the after market belts using a little harder rubber compound. I don't believe the reflash would cause this issue.
2010 Renegade 800R XXC
2011 Outlander 800R XXC
25TH INFANTRY is offline
When should I change my belt for the 1st time? 52brezelfenster Can-Am Maverick 5 05-16-2019 12:23 PM
defender belt change tool? kenner Can-Am Defender 2 10-09-2018 10:41 AM
Mav belt upgrade PN change? audiobull Can-Am Outlander 6 08-14-2018 10:25 AM
Belt change jeremy8122 Can-Am 2017 Models 5 03-19-2018 06:09 AM
CVT belt, change it or leave it Bumblebeegade Can-Am Renegade 5 11-30-2015 06:58 PM
