Fighting steering on fast trails ?? - Can-Am ATV Forum
post #1 of 11 Old 04-05-2019, 01:50 PM Thread Starter
Allycanam800's Avatar
Iv got an outty 1k but bought a rene 1k 2016 for a change, took it out and for the day and i was fighting the steering all day the front end was so unpredictable 5 years ago i had a renegade and cant remember it being like that.. sag os set at 30% rear and 20% front before i start fiddling on i was wondering on peoples opinions i can check to rule opions out..
Thanks in advance
Allycanam800 is offline
post #2 of 11 Old 04-05-2019, 08:05 PM
How's the alignment?
2013 Outlander 650 Max XT
BRP fairing, mirrors skid plates and rear box
SYMTEC hand/thumb warmers
Trapper front box
GARMIN Montana 600
styk is offline
post #3 of 11 Old 04-06-2019, 12:37 AM Thread Starter
Alls good on alignment... been through high / med / low on dps also
post #4 of 11 Old 04-06-2019, 07:00 AM
awful knawful's Avatar
What tires?
Pressure all same?
1998 Honda 300
2005 Polaris 50
2012 Can Am 1000XT, 15400 kms
awful knawful is offline
post #5 of 11 Old 04-06-2019, 08:14 AM
Dr_Z's Avatar
I assume you bought it used. If you were in 4x4, maybe someone put a torque locker in the dif?
2011 Outty 800XXC
Dobeck AFR+, Hayden fan controller, QSC Rev-X primary/STM secondary, TORQ Locker
Powermadd hand guards, RotopaX 4 gallon, Symtec heated grips, Homemade UHMW skid
My YouTube page
(mostly unedited track rides)
Dr_Z is offline
post #6 of 11 Old 04-07-2019, 01:53 AM Thread Starter
It does the same in 4x4 and 2wd
But it has 27 10 12 rear and 27 10 12 fronts would the tyre width on the front cause this. Pressures the same tyres are kenda executioners.. i will put my outty wheels on to test but still open to thoughts
post #7 of 11 Old 04-07-2019, 02:56 AM
Could be the tires.
Tie rods, ball joints & wheel bearings all good?
1998 Honda 300
2005 Polaris 50
post #8 of 11 Old 04-08-2019, 01:39 PM
25TH INFANTRY's Avatar
thats a wide tire up front and could cause a steering issue, would also make you more subseptable to hitting something. most of the bent steering components come from front tire impacts. theres 2 kinds of alignments, mechanical 'tie rods' and electrical through the power steering 'buds'. i would check those first. the steering stem could have a tweak there very thin and bend easily as do the steering pitman arm that attaches to the tie rods. slight bends on theses components cause the symptoms your saying you have. other things to check are ball joints and lower a arms. worn out front a arm bushings cause the front end to dart while excelerating and while at speed, oem ones don't last long maybe a 1000miles so if you got more milage on it than that there worth replacing with some garage product bushings that have a life tile guarantee.
2010 Renegade 800R XXC
2011 Outlander 800R XXC
25TH INFANTRY is offline
post #9 of 11 Old 04-08-2019, 02:14 PM
iam_canadian22's Avatar
10" wide fronts do grab more and is noticeable in steering but i wouldnt say to the point of fighting it. As mentioned possible it had a locker install, jack the front end and spin one tire and see which direction the other one spins. If swapping tires doesnt change anything and you dont see anything bent or tweeked have it plugged in to buds and make sure the dps is centered.
Sent from my SM-G960W using Tapatalk
16 maverick xmr: sport low bypass, amsteel blue synthetic rope,
to come: ALOT
'15 xmr 800: 29.5" s/w OG oulaws, Sirius led light bar, can am/yoshimura slip on, dobeck gen4 afr+, QSC primary SOLD
iam_canadian22 is offline
post #10 of 11 Old 04-09-2019, 01:37 AM Thread Starter
Going to put my outty tyres on this weekend.. and see if its that never had a good look at ballball joints so will check those 2day
Central Kentucky Trails? adrnln_ti ATV Trails 1 10-22-2018 04:59 PM
Power steering doesn't seem right? tjreishus Can-Am Outlander 6 03-25-2017 08:43 PM
Land owners blocking trails blairc2007 Can-Am Outlander 41 10-04-2016 08:42 PM
2014 800 xt power steering issue poor farmer/logger Can-Am Outlander 9 04-21-2016 09:40 PM
What size tire for rocky-terrain trails? CaptSlim ATV Tires and Wheels 4 01-16-2016 09:45 AM
