800R fuel pump replacement - Page 2 - Can-Am ATV Forum
post #11 of 83 Old 01-10-2010, 12:15 PM Thread Starter
well i just pulled the tank on my buddy's renegade and the pre '09 fuel pumps are the same. they are just a lot more of a PITA to get out since you have to pull the whole tank.
i really think the reason why i've heard of more '09 fuel pumps failing is because of the larger in tank filter. the previous years have a filter that is half the size, so you'd notice the effects of a clogged filter much faster. when that happens, we all know to drop the tank and clean it. since the '09's have a larger filter, my theory is once junk gets past the pump and clogs up the regulator, the fuel pump gets overloaded and that is what actually burns it up. that also goes well with my theory that the '09 style doesn't have an inline filter because the regulator catches what the in tank filter misses. the '09 style goes from the pump, to the regulator, to the single fuel line to the injectors. the previous style went from the pump, to an inline filter, to a Y, to the injectors on one side and to the fuel return line on the other, which went to the fuel pressure regulator. the two line system works better for putting an aftermarket fuel pressure regulator in to jack up the fuel pressure. in the '09 style, you'd have to remove the intank pressure regulator and put one outside the tank. its not hard to do, but not as easy as previous years. these are just my theories, and i have been dinking for four hours (yes, i started at 10:15 AM), so take it for what its worth, lmao.
got wake? is offline
post #12 of 83 Old 01-10-2010, 01:49 PM
very nice wake ? for you whats easest way to hook up a fuel pressur tester to the outty? 08 650 is what i have
silverz98 is offline
post #13 of 83 Old 01-10-2010, 05:22 PM Thread Starter
you can take out the fuel filter and put it where it goes, or tap in somewhere else. where it goes to the Y piece, you can remove one side, hook up the pressure gauge there, and use another piece of hose on the other side to the Y.
post #14 of 83 Old 03-01-2010, 04:12 PM
here's a funny question for you wake, im working on an 08 fuel pump (bottom style). How in the heck do you get the fuel line off the barb end of the pump? That short black line looks to be shrink fit or something, I can't pull it off without thinking im going to tear the line. May end up cutting it off and replacing with a regular piece of fuel hose...
dgraham225 is offline
post #15 of 83 Old 03-01-2010, 07:50 PM Thread Starter
i don't know. i didn't try taking that off when i cleaned out the tank on my '07. i just left them attached. knowing how i do things, i'd probably get frustrated with it, cut it down the side, then put another piece on it.
post #16 of 83 Old 03-01-2010, 09:17 PM
yea I was thinking the same. I come back out the shop to make sure the airtex fuel pump was the same as the 09 and thought about it, never went back out there, lol!
I dont think my pump is the problem, just the pre-filter was clogged bad. I just want to pull the pump so i can remove and clean the regulator as well. The funny part was it would still read 46-48 psi on a gauge just didnt have enough volume to run right under a load..
post #17 of 83 Old 04-01-2010, 07:06 AM
lunatic's Avatar
What style or brand of after market regulators works on the older style systems. What do you do with the old regulator? Do you leave it attached and run the original and a after market together? I want to jack up the pressure before going to bigger injectors first.
2006 800 outlander xt
lunatic is offline
post #18 of 83 Old 04-01-2010, 07:47 AM
Thank you for this post. I just brought my canam to the shop to get the fuel pump replaced ( after 1/2 tank it would run right) and they said they could not because it did not send a code to the computer. SO I will pick it up today and tell them I WILL DO IT MYSELF! This post was perfect timing for me. I should have just done it all myself anyway.
joseph9936 is offline
post #19 of 83 Old 04-06-2010, 09:50 AM Thread Starter
i'm pretty sure this is the one mrrpm recommended to me a while ago:
Magnafuel MP-9950 MagnaFuel EFI Regulators & Fittings
don't worry about the old regulator, it is set to 50 psi. if you have one that sets the pressure to say 70 psi, the stock one won't do anything (i think). the stock one is actually part of the fuel pump assembly in the old ones, so it is harder to remove.
post #20 of 83 Old 04-06-2010, 09:51 AM Thread Starter
i'm pretty sure at the dealer they can only get the entire assembly anyways, which is quite a bit more than just the pump.
Fuel tank and fuel pump prefilter removal, cleaning icanamcanyou Can-Am Service Bulletins /Recalls / How To 83 04-10-2015 09:52 PM
09 800r water pump vent line? Fcat7 Can-Am / BRP 11 05-27-2009 08:31 PM
fuel pump renegade 1382 Can-Am / BRP 8 05-24-2009 04:36 PM
fuel pump renegade 1382 Can-Am / BRP 2 12-07-2008 09:24 PM
fuel pump MRCANAM Can-Am / BRP 5 10-22-2007 02:06 AM
