Dalton Clutch Kit - Can-Am ATV Forum
 2Likes
post #1 of 11 Old 02-21-2019, 07:35 AM Thread Starter
Dalton Clutch Kit
Hey Everybody,
I am getting everything to complete a clutch kit from Dalton. After watching multiple videos on this, I feel comfortable with doing it myself. The only thing I am needing now at this point is the secondary clutch bolt/shaft and the "not reusable nut". Would any of you be able to lead me in the right direction for purchasing these items and what specifically they are?
Thank You!
xmrmac3 is online now
post #2 of 11 Old 02-21-2019, 08:17 AM
Overw8's Avatar
Are you doing something to the secondary ? If not, there's no need to remove it to install a clutch kit.
Sent from my SM-G930R4 using Tapatalk
Overw8 is offline
post #3 of 11 Old 02-21-2019, 08:38 AM
What he said. No need to touch the secondary.
Overw8 likes this.
2018 Renegade 1000XXC Triple Black, 27" HTR's, OEM Snorkel, Yoshi, PCV, Monster EFI, CVTech/STM, skids, Warn 3500S, Xtreme Grille Guard, heated grips, LINQ w/cargo box, rear hitch, fender flares, radiator protector, 2" bar risers, 1" SuperATV wheel spacers, race driven pads
EvilGade is offline
post #4 of 11 Old 02-21-2019, 09:44 AM Thread Starter
I have to replace the spring behind the secondary that meets with the helix. According to the videos, everybody has been stating I can't reuse the first nut on the secondary shaft that holds the secondary on. The second nut (locking nut) can be reused. I'm just wondering if this is a special nut with nylon material in it or not. I couldn't really see detail of that nut from the videos.
post #5 of 11 Old 02-21-2019, 11:53 AM
Overw8's Avatar
Not totally sure what nut is in question here, unless you mean bolt ? The later model bikes supposedly have a torque to yield bolt that holds the secondary in place, and your maybe not supposed to use reuse it ? My issue with this is as follows. S torque to yield bolt is tightened to " ◊ " torque spec and then so many degrees past that to achieve proper stretch in the shank, in order to maintain proper torque on the bolt even through heat cycles. I have 2 manuals 1 for the g1 bikes and 1 for the g2 bikes. Both only show a lb.ft. torque. With no instruction on how many degrees past to yield the proper stretch. That being said, I've had mine apart several times for routine maintenance and have yet to replace the bolts. I hope this helps ?!?! Good luck and have fun !
Overw8 is offline
post #6 of 11 Old 02-21-2019, 11:58 AM
Overw8's Avatar
Oh... and dont be forget the lock tite. I use a generous coating of red on both the primary and secondary fasteners.
Overw8 is offline
post #7 of 11 Old 02-25-2019, 07:19 PM
Xmrwarpig's Avatar
Hi bud.. I just installed my dalton dbo570m clutch kit .... you have the torq to yield secondary clutch bolt. BUY A NEW ONE..... I paid $14 at my local dealer for the bolt... better safe than sorry.... don’t use red loctite..it states to use blue loctite with new bolt. Torque to 15 ft/lbs then 180 degrees. I have a write up from dalton I’ll post below. Also buy the clutch holder tool to make sure your torquing correctly..... I have mine I can sell you for $100
File Type: jpeg 5A52CEF8-5156-4419-854A-B4ACA9A0D5DB_1551147571943.jpeg (738.9 KB, 17 views)
Xmrwarpig is offline
post #8 of 11 Old 03-01-2019, 03:35 PM Thread Starter
xmrwarpig,
Thank you for the advice. Is there anything special about the nut that I have to go to the dealer. Is it something that a hardware store would carry?
post #9 of 11 Old 03-02-2019, 08:49 PM
Xmrwarpig's Avatar
I dont think you can get the bolt at a hardware store and yea it is a special bolt...the bolt will strech with torq
post #10 of 11 Old 03-04-2019, 08:32 AM
DaveB's Avatar
Depending on what year machine he has, it may have a stud and 2 nuts on the secondary. My 2016 did. Primary also had a stud and nut with a locking set-screw.
Overw8 likes this.
Pain or damage don't end the world. Or despair, or f*cking beatings. The world ends when you're dead. Until then, you got more punishment in store. Stand it like a man... and give some back.
2016 Renegade 1000 XMR: "Suck My Wake II"
QSC primary, STM secondary, Yoshimura,
BRP Rad relocate, Monster EFI reflash,
Cecco post brace, Rigid LED, skids, blue plasma rope.
2016 Outlander 570L DPS: "Tank"
BRP snorkel and rad relocate, 27" Outback XTs,
LED, blue plasma rope, Fox shocks, Alpine Flex plow.
Past machines:
2012 Renegade 1000 XXC
2008 Outlander 400 EFI
2007 Outlander 800 XT
Lots of older non-BRP junk
DaveB is offline
Go Back   Can-Am ATV Forum > Can-Am ATV Discussion > Can-Am XMR
Can am outlander 500 Max XT 2010 dalton clutch kit RibeiroPQ Can-Am Outlander 1 02-07-2018 05:11 AM
Dalton clutch kits? Shawn-Rancourt95 Can-Am Outlander 20 04-07-2017 07:09 PM
Griffin clutch or Dalton clutch? Ribeye Can-Am Outlander 4 02-27-2017 08:45 PM
16 Outty EPI or Dalton clutch kit? Iceman56 Can-Am Outlander 4 08-12-2016 02:19 PM
outlander L 500 with Dalton clutch kit mcgoo Can-am 2015 Models 19 03-06-2016 06:50 PM
