New vfj full replacment can am clutches - Page 2 - Can-Am ATV Forum
post #11 of 835 Old 07-23-2013, 07:00 AM
Makes me wish i would of bought a 650 and not a 500
12RT is offline
post #12 of 835 Old 07-23-2013, 09:58 AM Thread Starter
VFORCEJOHN's Avatar
Originally Posted by hunter541 View Post
are these going to be reworked cv tech clutches,just curious there's not many clutch makers out there sounds like it will a good set up you have alot of experiance with clutch work for sure.keep us posted john!
no these are not cv-tech clutches, Comet, Polaris, or any other OEM clutch retrofitted to this application, these are being custom built to be direct fit with no modifications needed.
These will use conventional primary spring and fully adjustable flyweights and are 100% made in the USA, as is most everything that I sell.
When they are ready, I'll need some testers, but I'll get to that later.
www.vforcejohn.com (570)-773-1240 Slipon and Full system Pipes, FI tuners, Clutching, Custom Dynojet Dyno tuning for all setups. email [email protected]
VFORCEJOHN is offline
post #13 of 835 Old 07-23-2013, 10:00 AM
If its 1000$ I'll get the primary n secondary for my commander....
2012 can am xmr 800-
2012 can am commander 1000 all stock
xmr_rider_skeg is offline
post #14 of 835 Old 07-23-2013, 10:59 AM
hunter541's Avatar
well i'm within 60 miles i got a 1000 xtp waiting for some ground ripping products,it would be cool to get the programmer you talked about and the clutch work done!
hunter541 is offline
The Following User Says Thank You to hunter541 For This Useful Post:
Canamkayaker (11-25-2013)
post #15 of 835 Old 07-23-2013, 11:11 AM
mrrpm's Avatar
Originally Posted by VFORCEJOHN View Post
as far as engine braking, you will have it until the clutch disengages about 4-5 mph just like a QSC clutch or STM
No, the QSC will engine brake all the way down to the engine stops, just like stock, since it has a one way bearing. The STM don't have a one way bearing, so they will pretty much quit braking when the primary opens up.
Which way will yours do?
mrrpm is offline
post #16 of 835 Old 07-23-2013, 11:21 AM
Slyder01's Avatar
sounds good
If There's a Trail I Ride It...
If There Is No Trail I Make One...
RIDE ON!
Slyder01 is offline
post #17 of 835 Old 07-23-2013, 11:49 AM
awful knawful's Avatar
are these clutches going to be "locked" unlike the stocker?
1998 Honda 300
2005 Polaris 50
2012 Can Am 1000XT, 15400 kms
awful knawful is offline
post #18 of 835 Old 07-23-2013, 03:30 PM
brpbear's Avatar
I have a QSC and it has as good if not better engine braking as the stock clutch but when I put the STM secondary on I lost my low speed engine braking. The reason I didn't have engine braking was the STM had to many shims between the pulleys .
brpbear is offline
post #19 of 835 Old 07-23-2013, 03:52 PM Thread Starter
VFORCEJOHN's Avatar
the QSC I had setup ran a STM non e/b secondary helix that also required the shims between the sheaves, so it kicked out as well, about 4-5 mph even though it ran the center bearing on the primary it didn't make much difference. but if you have a lot of slack in the belt from too much shims, then it'll have little to none below 10 mph
This clutch will run a 1.75 diameter center vs the stock 2.25 bearing so if you are running a stock secondary you should have engine braking just like you do now.
engine braking really depends on how high of stall spring you have as well and how soon it kicks the sheave off the belt
post #20 of 835 Old 07-23-2013, 03:55 PM Thread Starter
VFORCEJOHN's Avatar
Yes, they will be complete and locked with a spider that is torqued down to the fixed sheave, no inner sheave and outer sheave movement, Plus a quieter operating unit
Go Back   Can-Am ATV Forum > Supporting Sponsor Forums > Interstate Motorsports
Renegade & Outlander rear cv boot or cv joint replacment astvadz71 Can-Am Renegade 6 11-20-2010 07:40 AM
Full HMF VS. Full MUZZY???? 11renegadeXxc Can-Am / BRP 22 11-17-2010 09:31 AM
CLUTCHES Can-am flyier Can-Am / BRP 12 03-16-2009 04:25 PM
Clutches 07ICanAm Can-Am / BRP 1 06-28-2007 04:07 PM
Full Skid Plate Package from BRP does not mean full! Can-Am / BRP 8 04-05-2006 05:34 AM
