Forum Discussions about this Product
1 - 2 of 2 Posts
    1. · Premium Member
      2021 Outlander 850 max XT-P
      There are empty relay sockets in the fuse box but I haven't investigated what it would take to utilize them. The quick solution would be to use something like in the link above.
      Hope this helps.
    1. · Premium Member
      In that case, others may feel different, I would install a relay to switch the direct battery source and use the plugs under the pod as the control circuit for that relay.
      I know it sounds complicated but it's super easy with something like this:
      This way the load is carried by the battery yet it's turned off with the key. The only time this is less desirable is when killing the power cause the device to loose its presets or memory.
      Hope that helps 👍
1 - 2 of 2 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
