I replaced mine with H4’s that had an internal fan and heat sink was not hanging off the back.
This way they can still have those rubber caps on the back.
I did have to gently dremel out the hole of the housing a little bit but a drum sander on the dremel, it took about two minutes.
keep in mind, your light pattern with an aftermarket LED will not be the same as the halogen , but I wanted more of a flood than spot as I have some additional LED spots anyway.
these are the ones I ordered.
AUXITO H4 9003 LED Headlight... https://www.amazon.com/dp/B07TQLK6SH?ref=ppx_pop_mob_ap_share
