trying to remove front axle with inboard hydraulic discs. do the torx bolts on the bracket have to be removed to remove the caliper? any suggestions on getting them loose? mine seem to be extremely tight.
that brackets is part of the caliper, yes those 2 torx need to be removed to get the rear pad off. Use a torch to heat it up, it has loctite on it from the factory.
