I read one or two with defenders, but not outlander.Very strange issue that has been going on for about 3 years. My 06 oulander 800 runs great all summer but once winter rolls around its very hard to get it to stay running until its warm. Summer you hit starter and it fires and is ready to go. Winter it fires right up revs up a bit then lowers the idle until it stalls. If I hold a steady throttle to keep it running the IAC closes until it stalls. I have to keep holding the throttle reving it up to keep it running and after it warms up its fine and good to go. Runs like a dream after as long as I dont let the engine cool down to much between uses.
I sometimes disconnect the IAC and it kinda stays running. If its -15 same thing but the colder it gets it starts blowing brown smoke and cylinders start to cut out. Seems to be really overfueling but is fine once I get it warmed up.
I finally got fed up this year and took to a dealer to fix it as I use it to plow snow. They tried IAC and map sensor and still wont easy start in the cold. Dealer didnt charge me for those parts which is great. Now they are thinking ECU or maybe throttle body. These I will have to pay for since they dont have them at $1000 and $1500 each.
The labour time is starting to stack up. Anyone had this issue?
Thanks
