I'm having issues with my rear transmission seal leaking and I have a new one and want to replace it. I unbolted the four bolts on my rear differential and was able to separate the propeller shaft. Then I removed the propeller shaft bolt on the transmission side.
Should the propeller shaft pull out off the splines of the transmission output shaft now?
I'll post a couple pictures in a minute or two.
I don't even think it was nessesary to remove the four 10mm bolts on the back of the transmission.
Shouldn't think just pull off now like the front?
Need some help here.
