I am having issues with my bike this thing only has like 160 miles on it. I took it through a buddies pond a few days ago. Everything was fine, I washed it up real good and trailered it home. Well today, I took it down to some land and tried to get it off the trailer. I turned the key the gauge cluster did its deal "check" and then it would just shut off. I have power, my winch works lights work, but it won't even try to turn over and the cluster goes out completely. No welcome message. If you let it set for 2 min it cycles the pump and the cluster comes on for a brief 1/2 sec and shuts back off. If you turn the key off and let it sit for a minute or two then turn the key back on while holding down the starter button it will crank and run for just a sec and then die along with the cluster. I have only ridden this thing twice. I did get deep in the pond and had to sit there for a few minutes. Today I pulled most of the plastics off and found that the three main fuses under the seat where completely submerged in water from last weekend. I also found that the air box was quarter the way full of water. I did not completely submerge this thing but just about ( got the water up to the stock snorkel not in it trust me I watched it like a hawk). After the pond I drove it up to the house and washed it then put it in the trailer and took it home. Today when I pulled the plastics off none of the fuses where blown I dried everything out that I could and check the fuse box under the gauges even switched out the relays. NOTHING!!! Please help!!! I am brand new to the CanAm movement and know nothing of these machines! Only Honda!!!
P.s. If I take out the relay that cycles the pump and gauges I can hit the starter button and it cranks over great just no fire due to the relay missing.
