2011 Canam outlander 1000 no power
143 views 5 replies 2 participants last post by  Chief...
Hi I have a canam 1000 outlander recently the battery went flat tried to jump start it and had no power anywhere, replaced the battery and the starter relay and still have no power replaced most of the fuses in both fuse boxes and tested the key and that was working, no voltage on the ignition fuse (f5) ecm module (f6) speedo/relay (f4) winch 2wd/4wd (f7) any suggestions
#2 · (Edited)
1st off, welcome to the site.
I had a 2012 Outlander and I seem to recall that there should be a stand alone 30 or 40A fuse, check your manual for where it is (the best of my recollection was it was located on the right side below the seat) but most everything dies when that fuse blows.
EDIT: I just looked at my owners manual for the 2012 Outlander and that 30A fuse is located in the rear fuse holder along with two 40A fuses.
There should be a stand alone 40A fuse, check your manual for where it is (the best of my recollection was it was located on the right side below the below the seat) but most everything dies when that fuse blows.
I’ve got 2 40A and a 30A under the seat that are all replaced one of the 40s was blown and had melted the bottom of the fuse box but still have voltage going through the new one
I believe that 30 A fuse provides power up to your main fuse box, if the main fuse was blown or the wires from the main fuse were broken that would explain why there is no power at the main fuse box.
Main Fuse Functionality in Can-Am Vehicles
The main fuse in Can-Am vehicles is crucial for the electrical system. It protects various components by providing power to essential systems.
Power Distribution
The main fuse typically supplies power to:
  • Ignition System: Ensures the engine starts and runs.
  • Lighting: Powers headlights, taillights, and other lights.
  • Accessories: Supplies power to additional features like winches, GPS, and heated grips.
  • Control Modules: Powers the electronic control units that manage vehicle functions.
  • Helpful
Reactions: Angore
