1 - 4 of 4 Posts
I have a set of 2012 Apache 360 Tracks and a lot of the wheel bearings are gone in the 144mm wheels. To replace the bearings you have to replace the entire wheel and that runs upwards of $70/wheel. Did anyone come up with a cheaper solution or find an aftermarket wheel that is reasonably priced?
The part number I am referring is: 715001605
Please help & thank you in advance!
Did you find a solution to your problem?
We found a way to use a hole saw and a dremel grinder wheel to replace the Camso wheel bearings. We can then replace the bearing and hold it in with a C clip like the 2009 Camso wheels did. Takes a lot of time but it works.
Hey all, did anyone else find an aftermarket wheel or another solution?
1 - 4 of 4 Posts
