1 - 4 of 4 Posts
hey guys bought a rene second hand i finally needed to use the winch on it the other day and i did not work :th_smiliepullhair:
just a clicking noise when i try in or out on the handlebars. its a warn 3500 i believe.
solenoid may be bad. I got a 2500 lb warn on my dads quad and if its used a lot in the summer it will get hot and quit working. all you can hear is it clicking when you try to get it to move in or out.
Motor is most likely burnt out . I've had 2 replaced on my 2013 xmr first one lasted 3 hrs then 6 months later go to use it and all get is a clicking sound again . Took it to Warn talk to tech he told me even with there sealed motor they still get water inside but have no way to drain . Tech told me to pull motor cover off every once and awhile and clean if riding in a lot of water. Motors are about $ 180.00
They should also carry a lifetime warrantee yes no?
1 - 4 of 4 Posts
