2014 Commander 1000 Question
1 reading
2.2K views 8 replies 2 participants last post by  Tony Mac
Hi all, this is my first time posting so please bear with me. I bought a used 14 Can Am Commander XT-P 1000 and decided to change the rear differential fluid. The Allen head of the drain plug was stripped when I first saw it, so after many tries, I used a screw extractor to pull it out. No problem there. The problem began once I tried to install the new OEM replacement. The new one is 10mm wide while the old is 9mm. I cannot find a replacement plug that will fit. Any help would be appreciated. I am thinking about using a die set to slim down the new one to fit. Or conversely, a tap to enlarge the current drain opening.
Welcome to the site, Tony
What part number are you using/looking for?
Well, that should be the right one, then.
I suppose it's always possible it was mis-picked/mis-bagged, prior to shipment. I'm dealing with that right now at work. Have you tried ordering another one in?
Reactions: awful knawful
So went to dealer and they tried to match. Nothing there that would match size and thread pitch (great idea by the way). Ran into a retired machinist who said he could silver solder an Allen wrench to the head of the old one( threads are good) I asked for it to be about 1.5 inches long so I could get a socket on it. He is making the piece now. Hope this works.
Interesting... glad you seem to have a resolution on the horizon, but sure curious as to why this has been such a chore thus far.
Anyway, back to riding!
#9 ·
Installed the old plug with the extension welded onto it. I used a little anti-seize on the threads and it went right in. Installed the skid plate and it gives me about 3/4 of an inch of clearance between the skid plate and bottom of extension. Now to put in the new gear oil.
