2015 800XMR cluster swap with 2015 1000XMR cluster
1565 Views 4 Replies 4 Participants Last post by  Loxboy1
I was wondering if anybody knows if I can swap out my Outlander 800XMR guage cluster with the 1000XMR cluster. I would like to have the analog/digital guage with the temp guage the 1000XMR has. A friend of mine has a 2012 outlander and did this swap with no problems. Anyone here know for sure this would work for my 2015 XMR?
thanks,
1 - 5 of 5 Posts
thanks,
Im sure you will be fine. Everything is the same from 2012 and up. I found a youtube vid of a guy who had the XT and swapped his out with the XTP gauge you just have to buy the gauge and the pod as well.
I want to do this to my 15 800 also. do you have to install a temp sender on the motor or is it already there?
Never heard of anyone having to do that...from what I understand it's a plug and snap in install....pretty easy from what I've seen...could be wrong though...
I watched a few vids on it. Gota buy a new pod also. The gauges are factory set to kph. Apparently you have to hook it up to buds to get it to show mph
1 - 5 of 5 Posts
