1 - 6 of 6 Posts
what is a R60 code my 450L CanAm Outlander turns over i can smell fuel and the dash is saying RRRRRRR R60 CODE. WHAT DOES THIS MEAN???
THANK YOU IN ADVANCE: JEREMY WERNER.
That's not a code that I know of, that's probably just a continuation of the display board failing. Your cluster sounds like it's kicked the bucket.
2015 outlander L 450
I have a 2015 450L too, hi bought it used and the gauge doesn’t work. The PO said it failed after 3 months. But, the fuel gauge and other displays work. No RPM or MPG. When you start it it gives a long RRRRRRRRRRR might be a 60 at the end, not sure. But then it just goes blank. I am going to try resetting some connections to see if that helps but I’m afraid the gauge is shot. $300.
Also it displayed the maintenance required message which I reset but, I don’t think the selector works either.
From my experience, backwards RRRRRR on the display means faulty display and there is no fix besides replacing it. Usually around $100-$150 used or around $300 new
1 - 6 of 6 Posts
