21 - 31 of 31 Posts
Yep worst part is removing the exhaust. Rest is not bad. If it was bad valves it wouldn't have good compression. I would do a leak down test.
Lol hopefully they didn't mean that. These motors have cam chains not push rods.
Unless they ment rocker arm.
Reactions: BombardierBomb
Not sure how they thought bent valve. It had good compression. Ask them if the valve was stuck open or closed.
I'm betting injectors are leaking.
Then it should have had real low compression....
Yah that is actually high from ones I have tested.
21 - 31 of 31 Posts
