Id start by chexking all fuses.you should have two fuse boxes. One by the battery and one up under the hood.
appreciate that, but all have been checked and appear fine, i even swapped a few to see of it would make a difference…..Id start by chexking all fuses.you should have two fuse boxes. One by the battery and one up under the hood.
Ok just wanted to make sure you knew there were two boxes.appreciate that, but all have been checked and appear fine, i even swapped a few to see of it would make a difference…..
I went out this morning, turned the key and the dashboard came on and it started right up…..so odd, do u think the gas just needed a little time to settle in?Ok just wanted to make sure you knew there were two boxes.
Do you have a multimeter? Can you test for voltage at key switch fuse and relay driver clock fuse?
I had it in the shop a month or so ago for a full service and they did a diagnostic test on the electrical system and said all of it was good….what do you recommend I look at next?No, you had/have an electrical connection issue.
Bad gas won't prevent the dash from lighting up, or the engine from turning over. Unrelated issues.
And the plot thickens...note: rodents chewed my wires, i repaired them and wasnt confident I did a good job but they said they couldnt have done it any better and the diagnostic test also checked out that all was good
