1 - 20 of 27 Posts
· Registered
My check engine light comes on, limp home comes on then goes out. getting p2020 code and gets worse as it warms up. p2020 is #2 cylinder misfire on injector bad ground or ccm, just put new injectors in. Any ideas?
Bob
· Regular Joe
2014 Maverick 1000r
Welcome to the site
Misfire can be fuel or spark-related. When's the last time you did plugs?
· Regular Joe
2014 Maverick 1000r
Where'd you find that description for that code? Searching the site here returns "P2020 Intake Manifold Runner Pos Sensor/Switch Circ Range/Perf Bank2"
· Regular Joe
2014 Maverick 1000r
Wait
So the code is P0202? And the bike has a tune on it from vivid racing?
· Regular Joe
2014 Maverick 1000r
Ok
P0202 search results return this thread:
Seems to be an issue with a wet or otherwise compromised connector at the #1 injector. What's the harness/connector look like?
· Registered
Discussion Starter · #11 ·
Ok
I will check it out.
· Regular Joe
2014 Maverick 1000r
And it's misfiring? Or just throwing the codes?
· Registered
Discussion Starter · #17 ·
It's hard to say it's misfiring, when it hits limp home it's running on 1 cylinder witch I understand that what it's supposed to do, than fires again and gets worse as it gets warmer or the longer I ride it. The RPM thing is more when it's cooler and warming up. Took my laptop with me last time 0201 and 0202 were coming up, I cleared them 4 times before getting home, about 3 miles.
· Regular Joe
2014 Maverick 1000r
Just spit-balling here, but I read where lots of X3 owners fought phantom misfire codes that ended up being caused by the MAF/T sensor. That 02 sensor code in addition to the misfire lends credence to the thought process. Do you have any way of swapping in another sensor? Hate to just go aim the money cannon at the thing....
· Registered
Discussion Starter · #19 ·
Is that the one on top of the air box?
· Regular Joe
2014 Maverick 1000r
On your machine I'm not sure, it's typically on the intake "manifold" of the v-twins I'm familiar with
1 - 20 of 27 Posts
