So the p drive won't really have anything to do with how it shifts other than there will be no friction washer. It just has a sealed needle bearing the belt rides on.
There will be no need for the Can-Am hump. It is the same engine with integrated gearbox as the hd7 defenders and looking at the parts diagram it will shift smooth like the big defenders. It may take a light hump to get in park just because it has to fall into a cog but all others gears will be perfect.
It will be interesting to see what they use for a secondary. The hd7 defenders use a slider helix style. So the helix rides on two little plastic slider shoes. Kawi and Polaris have used these in the past and they are do wear out so you wanna keep an eye on them. Im aure they will pry use it in the outty 700s.
Would have been much better if they used the 3 roller defender/x3 secondary that is adjustable.
O well can't have everything if your gonna keep the price down.
