Dayum son! Why was it left outside with no cover or a heater? Was was the red warning light that popped up after it started up? Low oil pressure light?Starts colder than this but I wanted to get a video of it. Happened to be -24 when I recorded this video. I have the display set to show engine temp.
Synthetic oils are extremely good nowadays and they flow pretty well even at -30. My defenders just stay in an open sided shed and it got down to -30 a couple days in a row and it started right up.Dayum son! Why was it left outside with no cover or a heater? Was was the red warning light that popped up after it started up? Low oil pressure light?
It's amazing that it can start, but wouldn't this cause damage to the engine since the oil is too cold and not fluid enough to lubricate the engine parts properly?
I was just going to ask what kind of battery you had in there!The reason mine started is because in the hole above the winch made for the radiator is a series 27 deep cycle marine battery. The battery under the seat would have never started the wheeler at those temperatures.
Lol, can't be any worse than anything else around Alaska that has an engine. Forgot to plug my truck in last night. -27 this morning. Started it with my remote starter and that Duramax fired up. Did some protesting for first 2 minutes but was able to run to work this morning.I was just going to ask what kind of battery you had in there!Damn that's cold!
Have you ever scoped the bores of your engine? I would be interested to see what kind of wear that would cause after repeated cold starts like that.
Most Porsche Cayennes that came from cold climates have scored cylinders. In really cold temperatures the piston expands at a faster rate than the cylinder. I guess the engineers of that engine had a "case of the Monday's" when it came to determining piston to cylinder wall clearances. I was just curious if you had any premature failure on any of your other toys because of the extreme cold temperatures of where you live. Guess not!Lol, can't be any worse than anything else around Alaska that has an engine. Forgot to plug my truck in last night. -27 this morning. Started it with my remote starter and that Duramax fired up. Did some protesting for first 2 minutes but was able to run to work this morning.
