1 - 1 of 1 Posts
Has anyone ever gotten one of those 6 gang switch panels to fit in an Outlander? If so where was the Relay/Fuse box located. The premise behind this device is awesome. Basically you make a single connection, direct to battery and then an accessory connection once. Then connect all your extras on directly to their own relay and fuse. In my case I am adding Rock Lights, Halos, Rear LEDs and Front LEDs. This device would help to make the install so much cleaner. The only issue is that the Relay/Fuse box is quite large (but not too large). It is certainly better than having to use 4 or 5 separate relays.
I'm not sure if I'm allowed to do this but here is a link to what I bought... the switch panel fits nicely on the factory plastic for switches.
1 - 1 of 1 Posts
