1 - 8 of 8 Posts
A buddy I ride with has a '08 Rincon that will start sputtering and lose's 95% power,sit for a few minutes and it runs fine.
Its been at the Honda shop on and off for 3 of the last 6 weeks.They have encountered the sputtering thing a couple of times while there,but cant find whats causing it.
Anyone?
An 08 is an EFI, might check the battery conections . Loose battery terminals create voltage drops, that really tend to jack up the ECMs. Sounds sort of similar to what happens to Can-ams or ACs when the battery terminals are loose.
Back in 05 I had that happen to my first Outlander, the dealer changed several parts tryu to fix it and in the end 3 months later the battery termial came loose enough to kill the bike and that was how we finally found the problem. Its worth checking. Same thing happend when I first got my Tcat. Except I knew then that the first thing to check on an EFI was the battery terminals, sure enough that was the problem on AC as well.
Sometimes it is the obvious,will tell him to check the battery cables.
ty
It was a gas filter that Honda just came up with to fix a similar problem,is what the mechanic said.
It was flat and the size of a silver dollar,soft,cloth feel to it.
1 - 8 of 8 Posts
