1 - 3 of 3 Posts
I have this problem always, but not fo often drive in really wet motocross track. So feels like ignition is not working well after driving through wet lands (rev not increase much and feels little vit like bad quality limiter).
When quad dry yp it starts to perform well...
Have you solved similar issues?
My plan is to add plastic cover to prevent water sprays to electricl systems...
Are you completely stock or what? Still have the metal box around the carb? Try using die-electric grease on your connections then shrink wrap them. What year is your DS90X?
Thanks for e hint, it is 2010 model. I will take few photos later to see if there is some protection missing. Cable connections seems to be sealed, but maybe I can still improve. Luckily it has been dry wheater so no urgent issues, but needs to be solved.
1 - 3 of 3 Posts
