A truly Canadian lift kit
3K views 9 replies 8 participants last post by  Sassenach
Ok. So I know I'm going to get sum WTF and you should not be doing that but it works better then you think. I know that you can buy lift kits for cheap on eBay but I'm the kind of guy that likes to make things if I can. this lift gave me 1 3/4" (44.45mm) of lift. I used Vulcanized rubber, to put it more Canadian hockey pucks. the time I took to make the lift and put it on was around 3 hours. I used 4 pucks a 2 1/2" ( 64mm) hole saw and a 1 3/4"(44.45mm) hole saw. First I used the 2 1/2" then the 1 3/4 to cut the centre out. after that I pulled the shocks took it a part slid it over. put the shock back together and back on the bike. look I used the pucks because they got some give but not a lot. this will help if I hit a bad bump. I took the bike out for a good shack down and found it was a bit smoother then before. the measurements are off the back off the frame. this was done with stuff I had kicking around. if you had to buy the pucks it would be $7 Canadian.
Machine Machine tool Milling Auto part Tool accessory
Vehicle
Auto part
thanks for taking a look and good and bad feedback is welcome.
No problems with that at all.
I've seen typical Sch40 PVC pipe used in the same fashion.
Ride on!
Good idea with the pucks. I ended up using some Cam Lock fittings on mine that I just cut down to length. I've got hockey pucks stacked up to get the correct bump stop length on my Jeep. Use what you've got.
Reactions: Freewill
#9 ·
Thats ok for a stop gap measure but all it does is increase your spring preload. I used cam locks machined to the same length for a while then upgraded my shocks with the Fox upgrade package from BRP. Wish I has just sprung for the Elkas and been done with it.
Reactions: Born2atv
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
