1 - 6 of 6 Posts
I have a 2005 400 max xt that's got a stutter when crawling and seeming when you first start moving but goes away once your moving at driving speed and I don't mean a fast speed but has to be more then just a crawl or it will stutter.
Not sure where to start looking I have had people tell me everything from rear diff to secondary clutch to valve adjustment.
Haven't had time to really look at it as I was in the middle of a move but should be able to start at it soon.
Any advice would be appreciated.
Thanks
Regular Joe
2014 Maverick 1000r
Welcome to the site
You're talking about an engine/power stutter?
Or a belt/clutch shudder at engagement RPM?
Regular Joe
2014 Maverick 1000r
So belt or clutch, then.
When's the last time you cleaned the primary clutch real good? What shape is the belt in?
I remember my spring cup was stuck in my primary on my bike, made for weird engagement behavior.
#41
Discussion Starter · #5 ·
It has been quite sometime as the machine has sit idle for about a 1 year and half or so. But the belt was good before that. I have also had suggestions that it could be in the rear diff a valve adjustment or the secondary.
Regular Joe
2014 Maverick 1000r
Highly unlikely.
If it's an engagement/off-idle issue, that's the primary. While you're in there cleaning it, change the one-way bearing and maybe grab a set of the slider shoes, those are cheap enough and quiet down the "back-n-forth" knocking noise, if you've got any.
1 - 6 of 6 Posts
