1 - 2 of 2 Posts
have been having problems with the Park/Reverse/Neutral/HIgh/Low shifter. Sticks in gear, and often have to shut down motor to move the lever. Now I've broken something, as the handle moves freely, but the ATV is stuck in Low. Help please!:sad:
I experienced this issue about a month ago.
In my case, the linkage connecting to the splined shaft from the engine had pulled out (you can just see the link on the "passenger's side" near the front of the engine once the seat is removed. The shifter connects to this point with a square block fitting - nut and bolt to secure the fitting. With luck, you can loosen the nut bolt, push the fitting back on and restore the operation. Note that this process is usually done in Park - you may need to fool a bit with it...
1 - 2 of 2 Posts
