1 - 3 of 3 Posts
I have a 2015 can am outlander 1000 max limited. When the engine gets warmed up the air compressor runs and air blows off. This keeps cycling until the motor is shut off or cooled off. Does anyone else have this problem and what could it be? Any guidance is appreciated.
Sounds like you might have a slow leak somewhere? Causing the compressor to keep kicking on in an attempt to maintain the system pressure it's expecting to hold.
Do you hear any leaks? Mix up some soapy water and spray the fittings at the compressor, lines, fittings at the shocks, etc, see if you can get something to bubble up.
1 - 3 of 3 Posts
