The hose routing as follows: From the nipple on the left side of the engine that points upward off the head. The hose goes to the air injection valve. It connects to the side that allows air to flow inward. There is a one way valve inside so you can blow air one way to check which allows air to flow in. The other port on the valve, the second hose connects there and runs down to the exhaust pipe which savages air from within the hose.
We removed the valve, cut off the pipe on the exhaust welding it shut, then attached a breather to the hose coming off the head and attached it up in the front wheel well. I have had a problem with oil leaking from the hose since then. No idea why but we did not use a new hose which we will try next with quality hose clamps.
I hope this helps.
