Has anyone successfully installed a wireless winch remote to their bike that has a limit switch for the plow? I am trying to install a Warn wireless remote to control my winch to my 2015 Xmr 800. When I purchased the bike, I had the dealer install the Alpine Flex plow which has a limit switch (Cable Saver) that automatically stops the winch from winding in when the plow is in the raised position.
The problem I'm having is, that the Warn instructions show a black and green wire coming from the rocker switch that is connected to the black and green wire coming from the back of the solenoid. The four wires from the Warn module are supposed to be connected to the switch and the solenoid. Fairly simple, but....the wires coming from my rocker switch are blue and green, and the wires coming from the back of the solenoid are connected to a red and green wire attached to the limit switch relay!
I've attached one picture of how the wiring is connected and the winch operates fine. The second picture is with the Warn module connected. In this scenario, the wireless winch remote works fine, and the "out" on the rocker works fine but I the "in" does not work. I've also attached an image of the cable saver limit switch relay wiring.
Any help would be appreciated.
