I have a 2012/2013 not sure exactly, pretty sure 2012 but it has a lift and extensions and I just got new rhino axles for the fronts and when I got it together I noticed the axle was rubbing on the housing of the wheel bearing and tearing up the axle. It’s not bad by any means but enough to leave a mark. Was wondering if I should grind the housing down with a grinder or the axles are wrong. It was hard enough to find a pair even long enough to fit but they did the only problem is it’s rubbing. What should I do???
