1 - 2 of 2 Posts
Gone are the factory sucky shocks in favor of Elka's Stage ridiculous...
Plugged the lines with 1/8" JIC plugs. Checked for leaks - none.
The system cycles every 30sec or so. You can hear the compressor kick on.
Eventually I get a maintenance required message which goes away when you key cycle it.
It's starting to get on my nerves. I could live with the error message, but the constant cycling of the compressor is getting old - fast.
I'm wondering if I put a small air tank under the hood if that would do it. Of course that adds weight which this monstrosity certainly doesn't need.
Suggestions?
Can u just disconnect power from the compressor? Would prolly still get an error msg but no more cycling
1 - 2 of 2 Posts
