Can a Can-Am 650 Xmr pull a wheelie?
14K views 23 replies 15 participants last post by  Linuxian
I have a 2013 650 Xmr that couldn't pull the front wheels off the ground on its best day. I've always assumed that it was due to the large tires and weight. Coukd anyone with a stock 650 Xmr confirm that is normal.
It MAY be able to be done with an aftermarket clutch setup. Even the 800s and 1000s can't do wheelies without replacing the stock clutching.
thats not true at all i cant keep my tires on the ground in high or low from a start doing a wheelie is just hitting the gas with a can am
Reactions: Jake_XMR
#3 · (Edited)
Yes
Edit this pic was taken stock
Still does it with outlaw2s and clutch kit easily
Clutching with outlaw2s
#9 ·
i have a buddy with a 650xmr that asked me the same question. i guess the answer is not all machines are build equally but a clutch kit would definitely fix that.
Reactions: Jake_XMR
i was talking about the 800 and 1000
#11 ·
Stock mine would wheelie no prob in low. Didn't try it in high. Now with a dalton kit and in low if I was to pin the throttle and pull back it would be over. In low with clutch kit I go about half 2/3 throttle with a slight pull back.
#12 ·
Damn! I can hammer that thing going up a steep climb with no worries about it flipping back. Forget about getting it up on 2 wheels on flat ground... I wonder if it's because Of my weight. I weigh about 260.
I gotta go on a wheelie diet lmao
#14 ·
linuxian
yes I think weight has something to do with it. I have 1000 xt with clutch kit and 27" outlaw radials and I have to work to wheelie, I am also around 260 lbs 6'2"
Reactions: Jake_XMR
#15 ·
Tho mine is an 11 650 they are basically the same.. Your weight, your body position when trying to wheelie has a lot to do with it, and where im from the ground is super hard pack and traction is minimal... But in low range it can be done
Now that mine is fully clutched it still has trouble getting traction but if I'm in the right area it will stand up
Reactions: Jake_XMR
#17 ·
sit ur butt back a little bit on the seat, hit the throttle quick and let off (low or high) then hammer the throttle and be ready to look at the sky. This method allows the front suspension to compress and then the shocks push back up and help the front end get up in the air. Be careful and have fun!
#18 ·
The OP mentioned a XMR, is there a difference in the clutching of an XMR and an XT? Many of those posting that they can wheelie are showing XT models in signature. I have a 2012 800 XMR and I can't the fronts off the ground but I'm a heavy guy also.
#19 ·
XMR should be geared lower, if I remember correct. Would make it easier to wheelie. The 800/1000 are in the max chassis so with the added length it does make it a bit more challenging to wheelie. It can be done though.
#21 ·
I go about 230, just get your butt back or shift back when you pull up. I was going to mention suspension too. I did notice that it got a little tougher after the spring lift. On my grizzly it wouldn't wheelie hardly at all with the suspension on max, but on soft or even half it would pop right up.
#23 ·
some of the comments surprise me. My bike with stock tires went fell vertical with my 200 lbs butt sitting normal and my 200lbs buddy on the front rack. now with the bigger tires I need to use a little effort in high but will wheelie all day long in low.
