1 - 20 of 21 Posts
Hi everyone, when I get on the platform it accelerates on its own. He has never done this in 6 years
Welcome .
What do you mean by "platform" ?
On the bike itself ??
And it wants to run away on you ?
I don’t care who you are this is funny
I’m still not understanding your post
Are you saying your throttle is sticking/ frozen open when you start it?
Ispezionare il cavo dell'acceleratore e il relativo percorso.
viene tirato sul corpo farfallato quando si girano le barre.
Discussion Starter #10
Proprio questo ho fatto oggi ed è perfetto, anche il collettore in gomma non ha crepe, purtroppo credo sia un problema di elettronica, può essere il sensore antiribalto? Sai dove si trova?
Bonzo
Would be interested on what the issue was
It's not solved , he's claiming it wants to accelerate as the handlebars are turned .
I told him to be sure the throttle cable is routed correctly and not binding as the stem is rotated and he insists it is correct .
I don't know what else to suggest .
Discussion Starter #15
Hi, today I solved the problem, there was the manifold of the throttle body almost out, all this happened because the engine moved 1 cm forward while the throttle body remained attached to the air box, so the engine sucked in air and accelerated only. Now post some photos and videos, thanks to everyone I can finally dedicate myself to the suzuki ltr 450 😍
1 - 20 of 21 Posts
