1 - 8 of 8 Posts
I bought a 2020 Can Am Commander that has a 2" lift kit with 30" tires.
Is there a 4" lift kit that does not involve portals? Looking for a couple more inches of ground clearance.
Scott
Not on factory axles, no. Those are your limiting factors. To get more than about 2.5", you'd need portals or a full axle/arm replacement lift kit, ala Super ATV or the like
Reactions: SuperATV
Vendor
^^^^Yep, like @BombardierBomb said.
You can add our forward offset A-arms which offer 1.5" more ground clearance, and will allow you to run up to a 32" tire...which will also give you another 1" of clearance.
Reactions: BombardierBomb
Reactions: SuperATV
That was what I had found. I was hoping against hope there was a lift out there other than the portals and axle/arm swap.
I will roll with the 2" lift and the 30 inch tires.
Thanks.
So, since I am 70's Chevy truck lift kit kinda guy and have zero side by side lift experience, I get to ask all the dumb questions. LOL
I have the 2020 Commaner 800 DPS. I bought it with what I was told was a 2" Superlift kit and it has 30" RC Lobos. If i bough these arms Can-Am Commander High Clearance 1.5" Forward Offset A-Arms....
Can these arms be in addition to the 2" I currently have?
Thanks.
Scott
1 - 8 of 8 Posts
