1 - 3 of 3 Posts
I have a 2019 outlander 450, and I'm looking to see what are the specs of the Valve adjustments with the feeler gauge? I'm looking to adjust mine since I lost power on it, and I will also want information on Timing adjustments if possible.
If any information is provided I will gladly appreciate the help and your effort. If not i'll try figure something out.
Thank you
Have you checked under your seat, on the VIN label? BRP used to post the valve lash specs right there, on the older machines, not sure about the new L models
There are no timing adjustments you can make
1 - 3 of 3 Posts
