1 - 2 of 2 Posts
Good morning you all so my chain fell off in one of my heads it did not cause major damage but it did brake the peg that hood the bottling chain guide now Is it absolutely necessary to have the chain guide installed since I have no place now to installed it or should I find a way to weld the stud in place ?
im assuming the original stud is pressed or screwed in their.. You are going to have to get that out and replace it... You will be very lucky if the valves did not get smashed by the pistons you are going to have to pull everything apart and check it out
1 - 2 of 2 Posts
