Can anyone possibly help! Commander won't start
11K views 5 replies 3 participants last post by  GRTWHTHNTR
I have a 2016 can-am commander 1000 max xt. I parked it in the garage over weekend and tried to start it and it wouldnt start. I had the battery tested and was told it was good and checked the cables. My lights and radio and winch all work fine just when I go to start it with push start I just get one click and nothing. Can anyone please help or any recommendations?
Sounds like you've got a loose connection somewhere- there's enough contact to power accessories, but not strong enough to roll over the starter.
Or the starter itself has randomly decided to **** the bed. With the winch working like you say, that'd be what I'd focus on. If it's cold where you are, they've been known to accumulate a little moisture/condensation in there, and freeze up.
Reactions: Clarence
Ok thanks I'll check other connections. Would you by any chance know where the starter would be located? Have tried searching and no luck. It has been cold we just had the coldest day of the year so my luck it's froze or it has taken a ****. Thanks you for the help.:)
Looks like it's stuffed back behind the clutch box backing plate, in-between the engine and transmission. Ouch....
