I just sent them an email through eBay, got an answer within half an hour. Here's their answer:
1. Change the speedometer from KPH to MPH or vise versa
<> yes
2. Change the welcome message that scrolls across the instrument cluster, and is there a limit as to how long it can be?
<> yes, you can change it, there is a limit, most support 25 letters
3. Change a low performance key to high performance
<> yes, if the ECU supports multiple levels, not all do
4. Reset the Maintenance Required message and change it to not come on as often.
<> you can reset it, but you can't change when it will come on, that is hard coded in the ECU.
5. Reset the tempature that the fans turn on and off
<> not adjustable
6. Reset the rev-limiter
<> not adjustable
7. Turn off speed limiter
<> not adjustable
8. If I get a new machine can I delete the old one and enter a new one
<> no, you must purchase additional licenses, after you use the 4 that it comes with. the system can be expanded up to 15, or to unlimited
9. Does this work on all Can-Am ATVs up to current models
<> we currently support up to 2014 ECU's and Clusters. We are working on support for the DPS and Air Ride modules. And we are working to add support for 2015 models right now.
10. Is there anything else that I will need to buy to make this work, cables, plugs, interfaces or what ever.
<> Just a windows XP or newer PC
I still want to check out the diag-systems and see how much more that one will cost and what it will do compared to this one. In my case I don't have anyone to help split the costs so I gotta make sure I get the right one the first time around.
Bob :tools1: :aniwheeler6: :tools1:
