1 - 10 of 10 Posts
What can I check or replace to be able to start my machine while in gear I can't figure it out Thanks :aniwheeler6:
Most likely on the master cylinder of the foot brake.
Reactions: Kingpate
Little brake light switch down in front of the motor on the frame...replace with NAPA Echlin # SL-134...about 1/4 the price of the Can Am one and same thing. Clean area real well. Don't touch brakes. Remove wires, loosen (i think you need a box wrench 7/8 ?), and gently take out with fingers. Teflon tape new one and screw in right away. If you do it gently, you won't have to bleed brake system.
Edit...picture of my ol Outty clutches....can see the switch....
Reactions: Kingpate
Yes, I had the same issue on my 2012 1000xt and the same solution.
1 - 10 of 10 Posts
