So I managed to do the engine oil with no issues, started to do the gearbox & followed the directions in the manual, I took the white plastic plug out, that's the oil level plug correct? The 2nd pic is the drain plug (see pic) However I can't for the life of me get a socket in there with the skid plate so close to take it off. I loosened most of the bolts on the skid plate to give me some space but the 2 up front near the a-arms are a PITA to remove! When I removed the white plastic plug it did drain some oil, do I need to take the other one off as well or no? I'm assuming the white plastic plug will be the filler hole? Thx for the help guys, first time changing the fluids on the Rene, didn't wanna fork out over $200 for the service.
