Hey guys, new to the forum and Can Am so I'm sorry if this has been asked before. I have an 2012 800 Outy that is slipping/jumping at slight throttle. I am pretty sure I toasted the belt the last time I rode (got hung up and it smoked a good bit then started the "jumping") so I replaced the belt but it's still doing the same thing. Looked like the secondary was the one "jumping". So I pulled the clutches last night and secondary looks fine but the primary looks a little damaged. See pictures. The bearing looks worn, the rear sheave has light rust ring and the outer sheave has a slight groove. Should I replace that whole primary or would these things even be causing this "jumping". I just don't want to go buying a ton of parts that I don't truly need. Thanks in advance!
