1 - 6 of 6 Posts
I installed my tracks on my 2020 max limited this year. I'm looking to get a little more performance out of my machine with tracks and/or tires on it. I've always felt the defender, with tires, performs well up to about 35 mph and then gaining speed is a slower process. Tracks always cut the speed in half and that really isn't a concern. When I get in deep snow the engine really bogs down. Sometimes I'll be down to 15 mph in the deep snow.
Question:
First, I know a clutch kit will reduce my top end; that is something I don't care about. I don't need to go 62 mph with my machine. Would a clutch kit improve my acceleration from 0 - 55 mph when running tires? Also, would that same clutch kit provide more low end grunt when running tracks. I would like to maintain 20 mph and keep my RPMs up when going through deep snow?
Thank you
Vendor
Question:
Thank you
Yes and yes. You have it figured out there. You are looking for a more torque...typically "bigger tire" clutch kit. Check with Dynojet and EPI performance first. They should have exactly what you need.
I don't know if you saw the posts on the 2020 Defender muffler problem, BRP issued a notice regarding the muffler expanding and the back creasing in. There is quite a bit of performance lost when this happens. It's easy to check, just look at your muffler, it will be obvious, if yours has this issue, Can-Am will replace it under warranty.
Font Material property Paper Document Paper product
Reactions: SuperATV
Yeah, it's to the point that when I see a rider with a 2020 Defender, I want to let him know about the problem. Let us know if yours has it.
Reactions: SuperATV
1 - 6 of 6 Posts
