1 - 8 of 8 Posts
I got a 2014 gade xxc all stock..what clutch spring do I change, what brand etc..& what benefits will I get from it..I'm new to the can am world..thanks y'all
I'm not really sure..I'm just wondering what it is for to change the springs, does it make it take off harder or what it does or what is the point of changing them
primary spring can raise/ lower engagement rpms. as well as affect top rpms but at a lesser effect
IT WILL MAKE THE ENGAGEMENT RPMS HIGHER. SHOULDN'T AFFECT TOP END TOO MUCH, but it may lower it a tad
Higher RPM takoff is great for better off the line drag racing or maybe mud. It will let you smoke the belt a lot easier if you do a lot of rock crawling type riding.
If you really want a better clutch, check out the VFJ or the QSC primary.
1 - 8 of 8 Posts
