1 - 2 of 2 Posts
Have a 13 outty 800, snorkel, slip-on, 28" Zillas
I bought your DBO800M clutch kit, I went ahead and installed the aluminum rivets as per instructions but decided to not install your secondary spring and leave the stock one in for now, since I have to wait to buy bigger tires now.
Shiftout was tested on a gravel road in 4WD
In low my RPM's shoot up to 7200 then drop to 7000 and hold steady
In high I never seen higher than 6800
My question is, if I put the secondary spring in how will it affect my shiftout?
Is it normal for the shiftout in H be significantly different than L?
Would it be worth it/possible to get my shiftout to around 7400 in L and 7000 in H?
To raise my shiftout roughly 200 RPM can i just take a slightly bigger drill bit than the hole in the rivet and drill some of the rivet material out?
Thanks, clutch tuning is all new to me.
Vendor
Without the secondary spring you have a DBO800 kit and the instructions, and set up guide for the flyweights is different without the offsetting pressure of that secondary spring.
In a DBO800 kit it would have told you to run the flyweights empty for that tire size.
If you would like to discuss further for your exact terrain and applications/options email me [email protected] (you will almost always be answered within an hour that way)
Thanks for inquiring.
1 - 2 of 2 Posts
