1 - 11 of 11 Posts
Under CAN AM/BRP there is a list of the codes at the top of the page so you know that’s where the picture came from
Yeesh.... yeah, kinda guessing game at this point. What symptoms is the bike giving you? May help reverse engineer the codes.
Discussion Starter #10
It didn’t have any, drive down the road fine with no sounds, turned it off and back on and after about 200 feet it turned off and said low volt (the battery is fine) and transmission signal fault. It will still turn over.
VR coulda kicked the bucket, these machines do all kinds of weird things when presented with low voltage situations. Check to see what kind of system voltage it's working with, might be the entire cause of the other trans signal fault code too
1 - 11 of 11 Posts
