Hey all,
I need to flush my coolant and refill. I have read in some places that flushing with distilled water and then draining and refilling with BRP coolant is fine. But, I've also read that using distilled water isn't preferred because it's really hard to get it all out so when you refill you are left with slightly diluted coolant, so flushing with actual coolant is better. Does anyone have any experience or suggestions here?
This is a story for another time, but I had to use some mountain spring water (used clean water bottle water but had to add some spring water as well) so I need to get it flushed pretty good.
I did search the forums but didn't see anything specifically on using water vs. coolant to flush and all the coolant threads are circe 2013 or so, so I figured a fresh one couldn't hurt too bad.
Thanks!
Thanks!
