1 - 15 of 15 Posts
Hello, I noticed strange noises and noises while driving, later I inspected the vehicle and noticed that the drive shaft shaft that goes into the gearbox is very loose and not tightened at all, there was even a leak because the shaft fell out. I tightened it as much as possible. I can because it is not really available. Why did it loosen, how much Nm should be tightened and could it cause any problem. I drive Can am 570cc
2016 Outlander Max XT 650
You can download the service manual from here and you will have access to all the torque specs you need:
Service Manuals for Can-Am Forums
Reactions: Dirty Red Neck
Regular Joe
2014 Maverick 1000r
Clean the threads real good and use some thread locker on the new bolt. Ratcheting wrenches are sooooo handy for this job.
I tightened the screw, there is no air in the joint, but now when I drive at 4000rpm I feel vibrations with my feet and on the steering wheel, when I accelerate the vibrations disappear. I lubricated the joint on both sides, do you have an idea?
Are you sure your joints are good ?
After tightening the new bolt, did you check if there is play/loose when you move the drive shaft up/down left/right ......... both ends ?
Regular Joe
2014 Maverick 1000r
Did the slip joint separate?
Discussion Starter · #8 ·
There is no fault in the u-joint, everything is solid, there is a little movement under the tires on the axle, marked in the picture. The machine has only covered 2500 km of easy driving
Auto part Cable Automotive tire Camera accessory Wire
Im wondering if you bent the driveshaft when it came out? Also like @BombardierBomb said check and make sure your slip joint didn't come apart and now the u joints aren't lined up.
Regular Joe
2014 Maverick 1000r
Just spitballing possibilities ;)
Driveshaft being out of phase could explain the new vibration 🤷‍♂️
Im guessing something is bent then.
Reactions: BombardierBomb
Discussion Starter · #15 ·
I will take out the drive shaft, inspect everything completely on the workbench, is it possible that the splines on the transmission shaft are damaged or those in the drive shaft are vibrating because of that.
1 - 15 of 15 Posts
